Left hand thread lugnuts
bob32268
7:25 PM
Johnstown, Pa.
I bought a new set of Magnum wheels with center caps and acorn style chrome lugnuts. Only problem is the lugnuts are all right-hand thread. Where can I get these lugnuts (see attached pic) in left-hand thread?
I will need 10 of them.
Tks,
Bob32268
can you convert the studs?
No, the studs are really tight, had to use a torch to heat them up and then pound out one with an air-hammer. It'll be much easier to just get the left-hand thread lug nuts.
Tks,
bob32268
Tks,
bob32268
You do realize that they are swagged in place correct?
Nope....how is this procedure done ? On my 69 Charger it was a piece of cake to remove the left-hand studs by pounding them out with a hammer and then insert the right-hand ones in the drum.
Tks,
Bob32268
It requires a special hole saw, just larger than the stud OD to machine the swaged area away. They are available to my knowledge.
I got lucky. When the Discount Tire tech broke off my lug stud, the swage went with it. I did a disk brake swap shortly thereafter, but there was a short time when I ran one right-hand stud with 4 left-hand studs on the same wheel.
Can you say wobbly wheels?
Better off using a press and supporting the flange AROUND the stud then gently pressing the stud out.
Using a hammer will, most likely, bend the metal where the stud was pressed in UNLESS you use a tubular support on the back side whilst hammering the stud out.
never did any of mine. Must've used the wrong hammer or wrong amount of force.
I just talked to Bob and he got fixed up through a local parts store. :thumbsup:
