73/74 Roadrunner Lower Control Arms
RR Fan Dan
If it ain’t broke, fix it till it is.
4:09 AM
Virginia Chesapeake Bay
I’m having problems locating bushings and pivot pins. Will 68-72 B Body LCA’s work? There are plenty of parts and options available for those. Do I have any other options such as a control arm from an A body or something like that? There seems to be no stock or aftermarket parts for 73/74 LCAs.
I’m having problems locating bushings and pivot pins. Will 68-72 B Body rear LCA’s work? There are plenty of parts and options available for those. Do I have any other options such as a control arm from an A body or something like that? There seems to be no stock or aftermarket parts for 73/74 LCAs.
Well if you were asking for rear LCA you will get a No.
They show everything.
But I already talked them and ordered a bunch of stuff. The complete LCAs are not an option for 73/74. Only the support brackets which I purchased.
Edited; My LCAs are fine and I can reuse them and probably the pivot pins. I really need the bushings. The pivot pins would be a bonus. My question is are there other Mopar LCAs that will work. I’m not opposed to modifications to make something work. The car is on the rotisserie now. Looking for all the suspension pieces to put it back together. The LCAs are my problem. I have found everything else.
But I already talked them and ordered a bunch of stuff. The complete REAR LCAs are not an option for 73/74. Only the support brackets which I purchased.
Yes rear LCA as stated in my post. My LCAs are fine and I can reuse them and probably the pivot pins. I really need the bushings. The pivot pins would be a bonus. My question is are there other Mopar rear LCAs that will work. I’m not opposed to modifications to make something work. The car is on the rotisserie now. Looking for all the suspension pieces to put it back together. The rear LCAs are my problem. I have found everything else.
Rear Lower control arms? Rear?????
No front. Similar to a 72 but apparently different. This a 72.
This is what they look like for 73/74
I know. I don’t know why I kept calling them rear. I corrected the thread. Y’all get a good laugh and then let’s move on back to my problem. If this thread is going to turn into a hey this guy is stupid thread I will delete it and move on so get your chuckles in now.
You mentioned years but not model of car. For Chargers, 73-76 takes the same bushing number. #12316 TRW from the catalog I have. As far as the control arm itself, I would imagine it is the same but I can't say for sure. You would have to go to My Mopar and download a parts book to check that.
74RR. Should be same as charger. But everything online only goes to 72 for b body
Hailing @hemi71x in case he has rebuilt LCA's for a '73/'74 B body; or knows where to find rebuilt ones.
Model does make a difference. Are you working on a Satellite/Road Runner and what year specifically? We need that information. That info should have been in your first post.
Hey. That looks like the right bushing.
70-72 and 73-74 do take a different bushing in the Satellite/ Road Runner models.
