- 5:53 PM
- Nov 21, 2008
- In GTXtacy Illinois
thath ludakwiss
You taking the pith?thath ludakwiss
The reason drilling releases a stuck bolt is because the hole allows the bolt to shrink by relieving internal stress. If it's heat you're abusing your drills. BTW, I use extractors regularly and rarely break them. I prefer "square" extractors, as the spiral ones tend to expand the bolts into the wall of the hole, thereby increasing the friction you're trying to overcome. With a square extractor, you just tap it in enough to get a bite, then any rotational force doesn't try to expand the bolt. One other tip is to not drill too large of a hole. That's to help prevent the expansion I'm talking about. At work I'm the "go to" guy for extracting screws.I drill with LH bits. A lot of times I think the heat inside helps as the offender sometimes comes out without using an extractor. What a relief
Absolutely. These are made by Rigid and includes the proper drill bit for each extractor. The set even comes with drill pilots for correct centering. They are splined and don't expand the hole like the tapered ones do. The nut slides down to the surface for more strength and less twist. When the end get's damaged from twisting or slipping, you can grind the bad end off and continue using the tool. These were a very popular sale on my tool truck.The reason drilling releases a stuck bolt is because the hole allows the bolt to shrink by relieving internal stress. If it's heat you're abusing your drills. BTW, I use extractors regularly and rarely break them. I prefer "square" extractors, as the spiral ones tend to expand the bolts into the wall of the hole, thereby increasing the friction you're trying to overcome. With a square extractor, you just tap it in enough to get a bite, then any rotational force doesn't try to expand the bolt. One other tip is to not drill too large of a hole. That's to help prevent the expansion I'm talking about. At work I'm the "go to" guy for extracting screws.
Best place to purchase?Absolutely. These are made by Rigid and includes the proper drill bit for each extractor. The set even comes with drill pilots for correct centering. They are splined and don't expand the hole like the tapered ones do. The nut slides down to the surface for more strength and less twist. When the end get's damaged from twisting or slipping, you can grind the bad end off and continue using the tool. These were a very popular sale on my tool truck. View attachment 1944785View attachment 1944793
Just check around on the internet.Best place to purchase?
Yes I have no faith in extractors based on past experience. I discovered a nasty problem with my 72 charger rebuild. It has the back tranny oil cooling attachment broken off with part within the casing wall. I may try gently with an extractor but doubt it will work and don't wish to break it off. I see some have used left hand drills so I will try that. Don't wish to get shavings into the tranny so hopefully the drill will exit the shavings all out ward. Having taken trannys apart, I have often noticed shaving in the bottom, so maybe mine can stand the odd bit of shavings.Purchased the set on Amazon a while back. Broke an exhaust stud, drilled it a bit then used the extractor with a 1/2 socket and 3/8 ratchet. Nothing heavy duty. Extractor broke and now I have a bigger problem trying not only get the broken stud out but the extractor piece as well. Evidently Chinesieum junk.
All drill bits exit shavings out the back. Good luck with your extraction.Yes I have no faith in extractors based on past experience. I discovered a nasty problem with my 72 charger rebuild. It has the back tranny oil cooling attachment broken off with part within the casing wall. I may try gently with an extractor but doubt it will work and don't wish to break it off. I see some have used left hand drills so I will try that. Don't wish to get shavings into the tranny so hopefully the drill will exit the shavings all out ward. Having taken trannys apart, I have often noticed shaving in the bottom, so maybe mine can stand the odd bit of shavings.
