Manual transmission spacers
Stucat
1:43 PM
69 b body . Does the 69 b body have those 2 spacers on the tranny mount on a manual setup? The picture in the MMC Detroit book and what I found on line only so an auto transmission. The spacer in the book show it as a washer? Shows it between the bolt and the mount. wouldn't a spacer go between the mount and the transmission? Thanks
??? What spacers ???
Assuming you're talking about the mount in the crossmember ... the bottom of the mount has a stud that goes through the bottom of the crossmember and attaches with a nut. The mount attaches to the trans with bolts. There are no spacers - anywhere.
Maybe someone was trying to straighten out a u-joint misalignment by raising the tail of the transmission?
I believe the OP was referring to the rectangular washers that are place between the mount and the bolt that retains the mount to the extension housing.
Square washers basically and my 70 4spd has them
Hmmm??? We’ve got six 69-70 B-body 4 speed cars in our stable and none of them have square washers between the transmission mount bolt head and mount.
Those square washers are 1970 and newer. When the mount change design.
They are not spacers.
With reproduction parts yu will find allot application widening to sell more parts.
