Need Air Compressor Advice
Try to find one with a 1750 rpm motor... it will be a lot quieter than ine with a 3450 motor.
I bought my C-Aire in '94 for $1030 from my NAPA store. 80 gallon tank. About 19cfm @ 90 psi. Barely adequate for my sandblaster okay for my blast cabinet.
Id buy a good used HD comptessor in a heart best. I mean an industrial unit not a home HD unit. Bigger the better.
I have this one, it's a rock star for the price, Made in USA, and 11.5 CFM @90
So time to revive an old thread. My car is at the shop getting restored. We are getting ready to sandblast and my shop guy wants me to rent him an air compressor because he said his air compressor won’t keep up with continuous blasting. He is using a 3/16" nozzle & 1/8" orifice. This is his blast unit he is using.
He is telling me that I should rent an air compressor that’s at least 200 psi because his air compressor is running 200 psi and his blast unit can’t stay blasting. First I have a hard time believing his compressor is running at a continuous 200 psi, but let’s say that it is. I told him that it’s not the PSI so much that matters but the CFM. An air compressor like this should be way more than sufficient.
Air compressors at 200 PSI are 400 CFM and twice as more expensive and not readily available for rent.
Am I correct in assuming that he doesn’t need 200psi but plenty of cfm? Do you think the 185cfm 125 psi rental will be sufficient? I think it will me more than adequate probably overkill. The grit we are using is Northern Tool
Clean Bite Premium Glass Abrasive Blast Media, (24) 50-Lb. Bags, Medium, Model# MEDIUM-1200​
No, you shouldn't require 200 psi. Like you suspect, it's the volume that does the work. I would be very afraid of warpage with high pressures. My Quincy is rated at 17.5 cfm @ 175 psi and it keeps up with my cabinet blaster and my sand blaster. If I have larger projects to blast, I find it to my advantage to take them to my local guy.
I would be concerned about warpage even running at 90 psi...
I have no problem using the blaster for jambs, engine compartment & undercarriage.. The main body panels I use either chemical stripper or a 8" mud hog... While blasting you can come back over the striped panels but stay back and hit them at an angle, not straight...You can do a lot of damage to sheet metal with a sand blaster....
All that said yes, it's volume not pressure that you need... 80-90 psi....
I would think the 185cfm/125psi would work. That’s the max cfm and pressure under ideal conditions. We know that not to be the case ERGO it’s probably running at optimal pressure and cfm. 120cfm/100psi would be my guess. Do y’all agree that this compressor would be just fine.
The compressor is fine... Make sure you read & understand post #27... Your guy not knowing what pressure he should be running scares me, things like that can easily turn viable projects into forgotten junk...
Now you’re scaring me. The guy is very detail oriented, and I’ve been to his shop several times and seen his work which is gorgeous, so this does surprise me a little bit too. On the flip side, have you seen pictures of my sheet metal in the project thread? I don’t think you could possibly hurt it anymore than it already is. :rofl:
Yeah, I just found the thread... Almost looks like someone sand blasted it, did crappy rust repairs & skimmed the whole car to cover up the waves...
I have the same Quincy. It does ok on my outdoor blaster. Looks similar to the one in the picture above, but no idea how similar mine is. Mine is TP Tools and is 35ish years old.
I acquired a dead 30+ year old Ingersoll Rand 2475, and rebuilt it for about an $800 total investment. This included converting it from 3 phase to single phase. It’s 2-stage and produces something like 17cfm at 175 psi. You can do this with pretty much any brand of American industrial compressor. Keep in mind you can only run up to 7.5 horse safely on single phase, 10 horse max. But if you find say a 15 horse compressor, you can simply gear it down by swapping pulleys so a 7.5 or 10 horse motor can handle it. So if a 15 horse is geared to spin the pump at 800 rpm with a 6” pulley on the motor, you can use a 3” motor pulley to spin pump with a 7.5 horse motor. Ya cfm will be reduced, but it will still make a ton of air. Keep in mind Chicom compressors from big box stores are pretty much throwaways after a few years because parts availability sucks. Also, Baldor motors are very spendy these days. Look for good used and sell the 3 phase motor to offset costs. Also gray ingersolls are made in USA. Tan ones are made in India.
We are only using it for the underneath to strip undercoating.
Not sure if you can still get “real” aircraft paint stripper. You know, the stuff that blisters your skin in 20 seconds? It dissolves old undercoating like you wouldn’t believe! Have lots of chemical proof gloves on hand, they last about 30 minutes‍
The real stuff is gone, it's replacement with the green label was junk,
there's a new version called "Ultra" isn't as good as the original, but it's much better than the green label...
cover the stripper with plastic and walk away....... it will keep the stripper from drying and allow it to keep eating the paint
