19bee70
Thanks 72...I'm on it!The 833 does not have a Neutral safety switch, back-up light switch only. The described/pictured wiring is the back-up switch wiring, nothing to do with the starter relay. As previously mentioned and diagramed, the unused terminal on the relay goes to the clutch pedal switch (at the clutch pedal) on manual transmissions, NSS on automatic transmissions only. You said you are not using it, that terminal on the starter relay needs to be grounded to function as intended. Review previous posts.
