fullmetaljacket
- 10:05 AM
- Oct 15, 2010
- Brooklyn, New York
You found him already. It's Chargercraze. I thought you might need a pair of those headlight buckets and that marker lens.Not seeing it.... Can you point me in a direction?
Truthfully, I'm not sure I need much front end wise, with the exception of possibly a K-Frame.
All of my suspension components appear to be okay. PLan is:
-.840 Torsion Bars from Charger Greg
-Stock lower control arms with Mancini reinforcement plates.
-Stock upper A-arms with offset bushings to add caster.
-Polyurethane bushings everywhere else.
-QA1 adjustable strut-rods
-Re-use all stock tie-rod and drag-link hardware.
-Re-use existing Calvert front shocks.
PS: Your comeback battle plan sounds very sound, but double check that drivers Calvert shock and its travel, It could have a bent main shaft, hopefully not. Carry on to carry those fronts when you return.
