Do I need to taste them?Make sure the plastigage is fresh....
Feeling them off should be sufficient lol. If they are dried out, it won't give an accurate reading.Do I need to taste them?![]()
I've seen worse.I'm really looking forward to cleaning this block out. I have a pressure washer and I'm going blast the crud out tomorrow.
This is a 1992, so Magnum. I would like to find a block. Or short block. Harder to find than you may think and at a reasonable price. Used could be a crap shoot. Better the devil you know.You going to find a different block/motor now? Only thing you would find here around ATL would be a magnum engine, as there's no old stuff (pre 1990) in the junk yards any more, only once in a blue moon. I bet this thing has been really hot at some time, from the condition it is in. Probably why it was parked.
This is something I have given thought. Am I more worried about coolant into the crankcase or bolts loosing torque or both? Some engines have wet head bolts that are sealed. It could work for a while or a long while while I rebuild other systems of the car and look for another engine.Sealer on the head bolts, ceramic sealer in the water jackets, run it. Just don't put a lot of money into it that isn't recoverable. (Heads and intakes can be re-used, sold)
Now I'm 99% sure I'm going to keep the EFI lol.I'm 99% sure I am going to gut the electronics and vacuum lines and run a carburetor intake.
