Front door window adjustment question
MikeyM
11:14 AM
NorCal
Hi all,
I was reading a few posts on how to adjust window glass and they helped quite a bit. I saw this post where Dad'sbee shows some pics which also helped: Window adjustment question
My question is - Is there a way to tilt the top of the vent window outward? When I close the passenger side door slowly, I can see the vent window and subsequent rest of the glass assembly get pushed outward as they close. I need to get the top of the vent window tipped out about 1/4 inch or so. In reading the manual, I see the "tilt, in & out", etc. and have adjusted the rear bottom nut so that the rear of the glass is just right but the front, I think, is about as far as it can go unless I'm doing it incorrectly.
Any advice?
Thanks,
Mikey
Yes. It adjusts primarily with the triangle piece near the bottom that bolts it to the door. Move the bottoms in and the top part will move outward
Hey PB, I'm not seeing that triangular piece you mentioned. MWBirdlover said the same thing but I'm not seeing it. Is it missing? I took a couple pics:
Below is looking toward the front. Sorry it sideways.
See the piece laying at the bottom of the door? That's supposed to be welded (or drilled and bolted) to the window track, and then an adjuster goes between that and the huge J-nut also at the bottom of the door.
and
Van's sells the parts:
https://www.ebay.com/itm/365624536069
https://www.ebay.com/itm/176740209168
I only know this because I had to buy them for my car.
Here are the links on Van's site:
Vent Window Post Brackets Mopar 1967-1972 A-Body 1968-1970 B-Body
Vent Window Post Bracket Adjuster Rod-Mopar 1967-1972 A-Body 1968-1970 B-Body
