FOR SALE A-833 OD 4-speed
68jim
10:26 PM
SE Virginia
Feedback: +0 / =0 / -0
A-833 Truck OD 4 speed (9-22-83) fits 76-86 truck/van. Steel shifter mount fits truck, levers are 68-70 B Body, unsure of shifter rods. Hurst handle and shifter body appear to be 68-69 B Body, Tail-shaft same as 70-74E & B (rear not drilled), Trans yoke. Picked up in a bulk sale - I think previous owner was looking to convert and put this in a 69 RR but never followed through (it does not currently have the B-body mounting plate). I disassembled, cleaned/lubed shifter and it works much better. Gears inside look good and shifts well. Will need a gasket kit at minimum.
$700
Can pick up/ship from Portsmouth, VA 23703. PM for more info.
68Jim
Any knowledge if it would fit a '75 B200, SB HD 318, factory 3-spd column shift bellhousing ? Any input appreciated, Thanks...
