1974 Roadrunner Re-Paint and Some Upgrades
Started narrowing frame rails and sand blasting. Battery tray area is ugly.
A list of suspension, brakes, and steering parts ordered and going back on the car
  • Bergman TBD” torsion bars
  • Addco 1.25” front sway bar
  • TBD LCA support brackets and greasable pivot shafts
  • Firm Feel tubular upper control arms with 1degree positive castor
  • TBD aluminum cross member and body mounts (iso delete)
  • AMD weld in sub frame connectors
  • Rear RCD Bilstein shocks
  • Front KYB Excel shocks
  • ADDCO 0.75” rear sway bar
  • Borgeson 14:1 power steering gear box and power steering cooler
  • 11” Wilwood front disc brakes
  • 10” rear drums with balanced drums and ceramic shoes, all other rear brake parts rebuilt with factory spec new parts
  • SS brake lines and SS brake hoses with PTFE coating inside
  • Leeds polished master cylinder and vacuum booster
  • Stock HD leaf springs
  • Flaming River tilt steering column
  • Urethane bushings throughout
  • All other suspension parts (tie rods, LCA struts, pitman arm, idler arm, ball joints, adjusting sleeves, etc..,) have been replaced with factory spec new parts
Did you find any more areas of concern?
Nothing yet other than what I posted so far. Lower rear quarters, battery tray area, small area around rear window, one area on rear floor pan, and the rest is pin holes and minor spots. Nothing that can’t be fixed. My body guy is one hell of a metal worker/welder/fabricator. I wish they made fenders for this car. The fenders are not rusted but full of dimples. Like someone took a ball peen hammer to them. Hood is rough too like that. New fenders and a new hood and there would be almost no filler required.
Nice, I was thinking it would be worse than that underneath after seeing your initial posts. Your fenders were perplexing, hard to imagine why they got so bad, hopefully a few hours with a couple of hammers and dollies can improve them a lot. Glad to see it being done right
The one thing you can get for these cars is floor pans and trunk. I think they were all replaced during the previous resto. One of them was already starting to rust through because it wasn’t sealed properly. They also went crazy with seam sealer. Globbed that **** thick in the trunk and other areas. Took some time to scrap all that out and of course there was rust starting to form already underneath because of improper prep.
I’m thinking an angry ex-wife or girlfriend.
