Air bag jack
qkcuda
9:46 AM
Jarvis, Ontario
I just saw this air bag jack listed on Amazon as a black Friday deal. I have a 4 post lift with a jacking tray, and I have a small bottle jack I use, which is a bit of a PIA.
Has anyone used one of these? For $100 it seems like a good deal.
I bought that exact one for the same purpose as you. It works fine BUT if you jack the car in the middle - like on the diff for example - it will sway to either side. Ideally you should jack one side and use axle stands for support.
It lifted the rear of the car effortlessly with on 40 psi. It'll go up like a rocket with 100 psi.
I do recommend this item - just use it with a bit of common sense and an equal amount of caution.
Watch Jack's, like a Flickertail watches cars from the side of the highway. Especially Chinese jacks.
Thanks man. I was looking at a similar one when I bought the lift, but they wanted $600.00 for it at the time.
Do you think this one would be more stable? One less bag, but with an extension it gives about 3 inches less lift height. This is very similar to the one the lift store sells.
I use this scissor jack with great success. It is rated for 1000# I believe, but I have had the rear of a B body on it many times. I don't remember where I got it though, maybe it was an accessory to a motorcycle lift I had at one time. With this and the hydraulic bridge lack, I can get the car off of it's wheels while on the 4 post lift.
That is a Triumph TR6 on the lift in the photo.
I'm going to pass on the air jack for now. As I mentioned, I have a bottle jack that will work in a pinch.
What somthing like this?
I have one of those air bag jacks and was raising the car at the diff. and it went sidways and fell over, luckily no injuries or damage.
I have 2 I use on my jacking tray. I love them. You might need to upgrade your air compressor to inflate them 100%. 140-150psi works good 110-120 psi not so much.
In my opinion, those air bag jacks just look like unsafe.
I would stick with a traditional, well-proven hydraulic bottle jack instead.
For safety, I wouldn't use either without jack stands. So to me, it becomes a convenience issue. I'm not sure I want to have to drag an air hose to wherever I'm using it. The bottle jack uses no power and a simple handle to pump it up.
Winner for me = bottle jack
Always use jack stands regardless. My air hose is next to my lift so it’s convenient. I like that I can store the air lifts on the jacking tray and still put a car on the lift.
For the first several years I had my four post lift, I didn't want to spend the money for a bridge jack. But I will tell you once you get the bridge jack, you will realize it money well spent.
I just purchased a Milwaukee portable battery operated compressor I now travel with. I wonder if this inflatable jack would work with it. Could be an asset during road emergencies. Not sure its max pressure , but it will do 40psi for sure.
Probably not. You need 130-150psi
