1966 B body - Hemi car question
gtx6970
12:08 PM
Tucson AZ
Anyone else seen this particular metal wire clip on any other car?
This pic is from the former Tony D #6200 mile car
It appears to be the same metal clip as the headlight wiring clip on the radiator support
Only this one metal but appears to be plastic / rubber coated
There isn't one on my friend's '66 Coronet...
But then I also see more modern wiring and terminals there. :rolleyes:
Nope, and I have a hard time with a plastic clip from 1966. I read that wrong... plastic or rubber coated, so like a speedometer cable clip..
It doesn’t look plastic to me, but I haven't seen that car in person.
No clip on mine. Don’t see mark on bracket where it could have been in past.
But has part number tag still on fusible link wire.
There’s a similar but much larger clip on my driver parking light. Mike Voltz noticed that when looking over car. And he hadn’t seen on other ‘66’s. And it wasn’t on Joseph Kwapich’s ‘66 parked right next to me. So there’s some inconsistencies with some clip placement on these cars.
It's like they were given one clip and told to put it somewhere.. LOL
I think you may be on to something.
These 66 hemi cars came out late: there was a HP2 batch then months went by with another final batch.
If production issues caused the lateness and production pause, those issues typically result in assembly variation
Yes, Mine has 2 metal clips holding headlight wiring to the radiator support. But they are bare steel
Mine has been restored so no idea if this clip was ever on the relay bracket , or not
I'll have mine out later today and will take a few pictures of the 2 up ft
I think these might be them or at least very similar to these
https://www.ebay.com/itm/145055422047?
Steve, yours looks like they are plastic / rubber coated?. The ones on mine are plain steel
That parking light clip is steel with plastic dip. Very similar to those new ones you pictured. I think the opening circular or the oval is configured perpendicular vs parallel as you pictured
