Cam for 440 street build
TrackPack
6:42 PM
Minnesota
I'm looking for input on a cam for a upcoming 440 project. It will be a pump gas friendly build for a street driven road runner with a 727 and 3000 stall converter. Have not decided on a rear gear, but most likely 4.10 or 3.55
I originally bought this 440 with a spun #5 rod bearing, but it was a low mileage .030 over cast piston rebuild. I plan to use as many of my big block parts that are just collecting dust.
Specifics:
67 440 block .030 - cylinders show little to no wear.
Replacement crank from early 60's 413.
Stock LY rods with replacements for #5 and #6
Cast Badger flat top pistons measured .086 below deck
Options:
915 heads pocket ported with 2.08/1.74 or Edelbrock E-street 84 cc
Stock cast iron intake or vintage Edelbrock TM7 Torker.
Stock HP manifolds or 2" Hooker headers.
Crane ductile iron 1.6 rocker arms or 64 Max Wedge 1.5 rocker arms.
The compression with the iron heads comes out to about 9.25:1 with steel shim gaskets. I prefer to go with a mechanical flat tappet cam and have found two that I think might work.
Comp Xtreme Energy 23-230-4
230/236 @.050 and 488/501 110
Comp Xtreme Energy 23-231-4
236/242 @.050 and 502/511 110
Thanks for any input. I'm not finding too many mechanical flat tappet cams in this low lift and duration range by any manufacturer.
Edit - 28 inch tire minimum diameter.
[1] Get a custom ground solid flat tappet from Comp Cams. I am getting one done now, $388. They have dedicated Mopar lobes that have more lift & area under the curve than Chebby & Ferd lobes.
[2] Be aware that the crank flange prior to 1962 will not accept a 727.
Question - what are you going to use for lifters?
I'm up for something custom ground, but would like some input on specs before I contact anyone.
This 413 crank is identical to the 440, so I'm thinking it's 63 or 64.
The later cranks that work with the 727 have threaded holes in the flange; the earlier ones have plain holes, drilled through.
Lifters. I wouldn't use anything made after 1995. Solids would be real hard to find. I get pre-95 OEM lifters from a junk engine & have them re-faced. I modify the stock hyd lifter for sol use by making a s/steel spacer to go under the piston. Real easy with the 440 because it does not have p'rod oiling.
Comparing hyd & sol cams. You have to take into account the lash of the sol. So, with the large 0.032" lash that the MP cams had, you would subtract about 15* from the 050 number to get a rough equivalent to a hyd lobe. Eg, Mopar 284/284 sol is about 241 @ 050; about the same as a 226@050 hyd lobe. Tight 0.018", you take off about 8*.
Looking at the specs provided, I would use these dedicated Mopar lobes from Comp, with headers.
Singlep attern cam, MM lobes.
Lobe#6582. 269* adv, 243@050. Valve lift is 0.549" with 1.5 rockers
108 LSA
Specifics:
Options:
If you have the e street use them
Torker or TM7 (two different intakes iirc but either beats a stock cast iron to death)
HP manifolds unfortunately. Maybe 2" headers if you run 4.10's
if you run 3.55's ^
If you run 4.10's ^
Those are hyd flat tappet,no?
I think you're getting the cart before the horse, so to say. You contact the cam maker and give them the info for gear and TC, tire size, etc and then they can match it to a cam profile.
To be honest, I'd rather gather some opinions before I contact anyone. I figure it can't hurt to gather some info beforehand.
Torker or TM7 (two different intakes iirc but wither beats a stock cast iron to death)
if you run 3.55's ^
If you run 4.10's ^
Thanks. Only hesitation with the E Street is that a composition gasket is needed, so compression drops to about 8.95
Comp cams 23-231-4 mechanical flat tappet:
Why not sell the heads you have and buy the 75cc E-Streets?
I could try to sell them I suppose, but shipping usually kills deals like this. Not sure how desirable the straight plug head with powdered metal seats are these days. The 915's are ready to bolt on, just need valve springs.
Just throwing this out there - but has anyone successfully used a low lift hydraulic roller cam with solid roller lifters on a combo like mine? I had ruled it out because of expense, but flat tappet lifters seem to be a real problem these days.
Get rid of those pistons. You'll break them revving up a cammed up engine. There are shelf flat top forged pistons out there. This should be your first priority.
Specifics:
Options:
I have a similar 440 in my 66 Satellite. here are my specs:
My engine is '75 440 bored .030, balanced, flat top pistons about .084 in the hole, 906 heads with performance valve job by Hughes Engines and new valves, seals, steel shim head gaskets, Edelbrock valve springs and performer 440 intake, Stock HP cast iron exhaust manifolds, 2 1/2" exhaust with Flow Master (I think) mufflers, 850 cfm Thermoquad carb, Comp Cam SK 21-224-4 cam and lifters (.488 intake lift, .491 exhaust lift, 274/286 duration, 110 lobe separation), Windage tray and hi-volume oil pump.
I suggest that you use a cam with 3 bolts to hold the gear on if you plan to use performance valve springs. I didn't and the single bolt came loose.
[/URL]
I ran the XE274 hydraulic cam in an 8.5-1 440 (sitting on the floor waiting for me to decide what to do with it)and it did fine. Withe the smaller of the cams you mentioned 8.95-1 is fine and the solid lifter cam should make more power. I am sure it would run fine with the 915 heads but I bet it would run better with the E streets regardless of the chamber size.
Good advice, but I didn't want to go full machine shop mode on this project. Forged pistons would require a hone to fit for piston to wall clearance or possibly another over bore if I raised the CH, and then some aftermarket con rods and rotating assembly balance for sure. Might as well have the deck squared up as well since it varies about .003 from end to end. All good things to do, but on a future project planned after this one - a 400/512 with trick Flow heads.
I like your cam specs (close to a Howards hydro I have in a 400), but I really want to avoid hydraulic lifters on this build.
First thing is lose the pistons and build a quench motor, I did and its a beast. 915 heads ported/polished, light weight JE/SRP pistons, Mopar .528 Mech Cam, 6 pack setup, perfect .040 quench with .020. steel shim gasket. 520 HP on pump gas with dyno headers.
