Too Loose Small Block Dipstick Tube Options
Dibbons
9:23 PM
La Paz, B.C.S., Mexico
When I re-inserted the same dipstick tube in the 340 I rebuilt, sure enough it was a tad loose. Now that it's installed and running in the vehicle, it wants to just fall on out. The silicone or whatever I used to secure it was a complete and utter failure. Any leads for me on a decent replacement? Working on a '72 Satellite Sebring Plus.
If both surfaces are clean, maybe JB Weld will help take up the gap and also secure it place.
I have had the reverse problem in the past where the aftermarket tube is too big for the block hole.
This is where the tube fits in the timing cover? Might try one of the chrome plated tubes, they are usually oversized since the plating is over a standard diameter tube....
Oops.. Yeah, block... It's a Ford small block that the stick goes through the timing cover... Same general area...
I’d roughen the end of the tube, sandblast, 80 grit, something like that, especially if it’s chromed, then use the slow setting JB weld. Make sure both the hole and the tube are completely dry. A little in the hole, a little on the tube, fasten it, let it set up. Personally I rarely ever use silicone on anything that comes in contact with oil or fuel or coolant, too many times it just doesn’t seal.
