eagle1969
Hi a couple questions... My first resto on a mopar. I was noticing the left front of my car is slightly lower than the right. Is that shimable? Its only about a inch or so, I didnt see any bends or damage to the frame and at the firewall it almost measures even to the ground, the frame seems to measure even to the ground,its the body. Also, the motor mount bolts seem loose at the front should they be a shoulder bolt or a spacer installed. The ones I looked at to buy are not thicker at the top. Not sure what to do any help is welcome.....
