Seat Belt Question
frank
8:15 PM
Harrington Delaware
I have a 1969 RR; took out the shoulder belt that hangs just above the drivers and passage side window. One end of the belt is bolted into the side the other has a buttons on the end. My question is, the end with the button where does it button on to; either the button on the belt or behind it (on the roof.
You should have a snap near the coat hook. If not you can feel the hole for the screw threw the head liner
Thanks
So the end snaps to the button next to the coat hook no to the belt it-self. I know the elastic stretches out but I would like to keep it looking original. Thanks for your help
The buckle goes to the visor, the belt is anchored at the bolt you see and the elastic snaps near the coat hook!
