68 coronet
I need a connector and the wiring for a 1968 Dodge Coronet, mine is bad and I cannot seem to get the connectors out of the plastic holder that plugs into the switch. The car will start and stall once you release the key but if I reach under and wiggle the wires it will start up and run. tried everything from cleaning to checking for a loose connection. So I figured I would cut out old connector and replace with another as a last resort. SO does anyone have one laying around?
