The Satellite Cometh
Happy Father's Day All!
Well, I took the car out for some fun on Sunday, weather was perfect. Took a few of my guests for rides and whatnot.
My issue is that the car seems like its not as quick as it should be.
My set up, as told to me by the previous owner is this:
1969 HP 440 block and iron heads
Bored .030 over
Steel crank
"slight edge ground off the port area of the heads" (whatever that means)
Mopar Purple shaft .509 lift
2.73 open rear (it IS a Satellite after all) need to address this, I know
TCI 1800-2200 RPM stall converter
As for right now, my theory is that I am "overcammed" or "under converted". It goes OK upstairs with the 727.
I am thinking that the .509 Purple cam is too much for this application. And/or I need a higher stall converter.
What do you all think?
Any thoughts/opinions GREATLY appreciated.
Don
Bored .030 over
Steel crank
Don
