six pack carb parts
g8rb8
New Member
1:50 PM
notus Idaho
I have a set of six pack carbs that I am looking for parts for.
I need throttle shafts and butterflies for all three carbs as well as the screws and linkages for vacum pots and acc. pump. Also need choke and shaft. Also if you have any info on what carbs I can rob these parts off of p.m. me
The choke and shaft should be the same as a Holley 4 BBL. The safety linkage is available as a repo but I'm not sure about the shafts. Have you called Holley to see what they may offer?
the choke shaft is the same as standard 4bbl but blade is like an 850 with a short tower. all the parts are availiable from the holley custom shop and ain't cheap.
