Rear end swap question
The housing width will be different for the Charger than the Challenger, but almost anything can be made to work.
Here is an axle chart I copied from moparts. It will give you the deminsions of both axles. You will most likely have to shorten your dive shaft or get a different one.
Housing widths, flange to flange
A BODY
'66-'72= 52 5/8"
B BODY
'62-'63= 53 1/4" (And '64 Max Wedge)
'64 = 55 5/8" (Exc. Max Wedge)
'65-'67= 54 1/4"
'68-'70= 54 15/16"
'71-'74= 57 7/8"
'71-'73 wagon= 59 7/16"
C BODY
'65-'69= 56 3/4"
'70-'71= 57 7/8" (Chrysler & Fury)
'70-'74= 59 7/16" (and '69 wagon)
IMPERIAL
'65-'66= 57"
'67-'69= 57 3/8"
'70-'71= 54 3/4"
'72-'73= 59 5/8"
E BODY
'70-'74= 56 31/64"
A100
'65-'70= 56 3/4"
D100
'65-'71= 58 5/16"
'72-'74= 59 7/16"
Hope this helps you out. Matt
I got to laugh at the 56 31/64" measurement. The factory was doing good to hold tolerance to 1/4" on rear ends lol.
No kidding. I've done alot of comparisons of this chart with actual rear ends. Also with trying to get the fattest, biggest tire on a car. The perches are usually 1/4" one way or the other.
I was searching Craigslist and stumbled across this. First question is would this work on my 1972 charger factory 8 1/4 318/904 car? Second is this a good price for it?
Will this rear end work in mine?
The E-body rearend is a little narrower than the B-Body rear but it will work. The price on that rearend however is high. Most E-Bodies came with 8.75's so the E-Body housings are pretty plentiful and inexpensive as are the 10" brakes. The suregrip center sections run around $350-$400.00 for a good used center section. The housing, axles and brakes aren't worth $300.00.
Joe
