Dodge440x6
has anyone had there six pack set up rebuilt? If so where was it done and are you happy with the results.
you do nice work.I've been doing them for 25yrs as pictured.Other than like this you can do them yourself,if you can take them apart you can put them back to gether,like Lew said not rocket science !
where are you guys getting your carbs replated? They look beautiful.
great photos thanks again. where do you get your rebuilding kits from?
I heard of a company that makes new base plates that moved the rear adjustment screws to the outside to make them more accessible. On the carbs I owned the shafts were worn and were a little lean from excess vacuum leaking arount the shafts. the new base would help that along with the adjustments. IMO new maybe better than dealing with worn 40 year old carbs.
