- 2:30 PM
- May 14, 2011
- On the Ridge, TN
Hi all-
Looking for some of you experts to help me out here.
My '68 GTX, as some may recall, was bought last year with a "mystery" motor in it - I simply have no information whatsoever on the engine.
I was told by the seller that it was a fresh rebuild by a now-deceased Dodge dealer lifetime mechanic and that he wanted to build a "beast".
Here's a video of it running:
http://www.youtube.com/watch?v=NSbOtCBqIZU&feature=g-upl&context=G2abe6b6AUAAAAAAADAA
There's another video in my youtube account of it as well.
Now to my problem:
I put a brand new Holley 3310 on it (750 vac. sec.).
Trivia: the one Holley developed for the '69 Road Runner originally.
I've used this carb on several 440s over the decades and it's always been a right-out-of-the-box sort of thing; just set mix and throttle and go.
Not this time. This rascal loads up just idling, despite my dialing in for best vacuum and rpm, so much so that it runs you out of the garage.
If you look closely in the video, from what I can tell it has around 6 psi vacuum @ idle.
The rest of the tuneup is fresh and it has the Mopar electronic ignition on it.
I have replaced the fuel tank, lines, pump and fuel filter as a course of going over the whole car.
Questions:
1. Am I right to suspect the power valve is open at idle, due to the relatively low vacuum? If so, what power valve should I swap in?
2. Can anyone take a wild-arsed guess as to what cam is in this thing by sound alone?
I wish I could tell you anything more about the engine, but I got nothing.
P.S. Yes, I'm aware that's an old small block radiator in it - I'm on the lookout for the proper one.
Thanks in advance!
Now to my problem:
Questions:
Thanks in advance!
