Donny
- 10:30 PM
- Aug 28, 2009
- North East San Antonio TX
Hey roadrunnerman, thanks!
I got the rest of the trunk floor completely welded in today, (the other side) and finished welding up the right side pan too. Man, there's a LOT of spotwelding everywhere for sure! I'm going to grind down some of the welds, the plug welds are (mostly) flush as I run a very hot torch (each weld is a near-disaster weld thru) and the trunk pan welds I will dress up a bit, same with the floor pan welds. I also lowered the GTX rack/dolly jig thingy 2 inches, set it on, then off again to the lift to get more underside areas. I'm also going to tie the roof skin back down, as with the cowel cover, so, more spot welding for sure!
I just now need to hire me a clone to set him doing the other tons of **** I need to do myself!
I just also noticed I'm not a Gold Member anymore, must have run out of my yr program, will renew asap. Will have some pics tomorrow.
