I don't have the parts you need but I think it makes a difference to what kind of power steering pump you have. The brackets are different from one type to the other. I am not sure about the pulley but I do believe they are different also. Good luck in your search and list more info. if you have it.
I have a bracket that I just removed from a 71 Nyer. It's different than the two piece arrangement on my Satellite but I could have used it with a shorter belt. Federal pump,Inverted flare with o ring fitting, rear mounting hole on back of pump is towards the bottom. $35, shipped PM if interested. Can't seem to do pics on this site.
Sorry about the late reply. I did dome research and discovered that the pump set up I had was for a 340. I knew it had to be a small block set up when I placed it next to the engine and it did line up. It was a free from a guy that had a shed full of parts
I found the correct brackets and pulley needed to get it going.
