1967 Coronet 500 383/4spd
maddart
1:42 AM
Homer Glen illinois
This 1967 Coronet 500 383/4spd is an original California car
The original date coded 383 (126000mi) was rebuilt by Book Racing using Keith black 162 .030 over 10:1 pistons, ARP bolts, comp cam pushrods, 915 closed chamber heads reworked with Ferra stainless valves 2.14” intake/1.74 exhaust, Sealed Power CS661 cam Duration 214/225 Lift 448/463 motor has 800 miles on it. Aluminum pulleys, chrome brackets, etc.(Approx. 400hp)
Flowtech ceramic coated headers, starter blanket, new aluminum radiator with dual electric 10" fans and adjustable temp controller.
New under hood wiring (connections all soldered), New chrome alternator 75A, New regulator, New water/fuel pumps, New Holley 750cfm vacuum secondary and lokar accelerator cable.
The A833 Trans has a New Hays clutch/ pressure plate setup and New clutch linkage. 8 ¾ sure grip (742 case) rear with 3.23 gears and New adjustable pinion snubber.
The 2 ½" exhaust is all New with thrush welded mufflers. New front suspension including RMS tubular control arms, all New bushings, New .96” torsion bars, New shocks, New Brakes. Driveshaft has been balanced by Chicago driveline and New u-joints installed
Manual steering, manual brakes. Original Inland 4 speed shifter. The interior is in very nice condition. This is a Nice clean Mopar
The panels, pans and paint are rust free original, but needs bodywork/paint to be amazing.
Many more (80+) photos at: http://s625.photobucket.com/albums/tt337/maddart4668/</a>
This car was purchased on 12/17/1966 by John Vukovich of the Philadelphia Phillys. Have an enormous amount of documentation including the Chrysler historical society paperwork, receipts and Certi-card.
Car is Located: Lockport IL. 60441
Possible Trades:
78-81 z28/68-72 cutlass/67-69 dodge dart
(No bikes-trucks-vans) $16000
Any interest in a modded 2000 SS camaro? 55k ish miles, cam th400, tubular suspension, pro star wheels with new hoosiers?
Modified by staff-No email addresses are permitted, no telephone numbers are permitted and no physical addresses are permitted.....PLEASE read the posting rules.
