Dan69rr
Hey Guy's, Time to sell the motor, Here what I have
1971 440 RB block, 12 1/2 to 1 Wiseco flat top pistons,.990 pin hole, Callie (hemi crank 4340 material, mains 2.750, rod journals 2.375,) 8 bolt flange, main caps (aluminum w/arp studs), Eagle rods 3-d h-beams(6.760 w .990 pin holes), Indy 440-1 cnc 345, Indy intake 6.750 tall, Indy valley cover, Indy valve covers.
Manley Valves Int. 2.250 w/ 11/32 stems, exh. 1.810 w/11/32 stems,
Manley Valve Springs- w/10 degree keepers, titanium retainers, double springs.
Jessel roller rockers 1:55 ratio
Jessel solid roller lifters
Milodon gear drive w/adjustable bolt pattern cam gear
Milodon 7qt. oil pan w/single external oiling system
Milodon external pump w/swing pic-up
Comp-Cam 690 lift 323 duration @50 w/ 108 center line
Motor has been blue printed, balanced, line-bored, deck for squareness, deck plate for straightness.
Asking $11,000.00 have much more in it. I do have a Barry Grant carb that needs work 1230 cfm It will go with the sale, All assembled. Motor will make over 800 hp, Any questions pm me thanks for viewing.
