Feral
If they priced it that cheap, look out! Ballparks are for fun and games, and that ain't gonna be fun.
I suspect you have a can of worms, just no one has removed the lid yet. When they do, the price should go up if it's done correctly. I've opened quite a few of those cans, and I'm speaking based my own experience.
You mentioned you have a used trunk floor and quarter sections from another car, and they need "minimal patching". The labor for removing and repairing those parts will probably exceed the cost of new parts. Judging by the condition of the floor, the inside of the torsion bar cross member is rotten and thin, if not eaten through by now. Where the driver's side frame rail joins the cross member is probably toast, too. Is there swelling around the spot welds of the shock mounts? Remove the front wheels and check the top of the frame rails where the upper control arm is mounted. It's like a tray that holds dirt and crud. Make sure it's not eaten through or so swollen between the layers that it needs to be cut out and replaced.
Your left rocker is shot and so is the lt. hinge pillar. Very possibly the inner rocker is eaten away also, where it joins the cross member. If you can, trim away enough floor to determine how solid the adjoining metal is. Peel away the floor pan above the cross member and dig the dirt out of it. Remove the dash assembly and heater box, seats and all interior trim. Pull the gas tank out, drivetrain too if it's going to be rebuilt.
I'm not trying to discourage you from taking this on, only trying to enlighten you so that it doesn't end up being a dream you dump lots of money into that exceeds your finances or ability. Good luck!
The "ballpark" estimate doesn't include parts, so it would be closer to $8,000. That's assuming I don't need to buy even more parts.
About the frame, once I park the car somewhere out of the weather I plan to deconstruct what I can of it and I'd like to pull the front and rear frames out from under the car entirely. Me and my father can handle whatever work that needs to be done to the frame.
The inner rocker panel is in good shape, I pulled the skid plate off and the rusted sheet metal is limited to what is seen in the picture. I poked around inside that with a screw driver and it feels solid, but I'm no body man, so... yeah...
And "hinge pillar", I'm assuming that's the section where the door hinges are mounted to the body; that's solid.
http://s279.photobucket.com/user/3440matt/library/1971 Super Bee?sort=3&page=1
here are more pictures of the car from the person I bought it off of.
I feel your pain. Unless this car is especially important to you, I would spend an extra $3-5 K for a car that does not need floor pans or extensive metal replacement. Unless you have a lot of sheet metal fabrication experience. Things like this is what stalls out a rebuild project. Good Luck.....................MO
Other than the fact it's a Super Bee, and a car I thought I'd never have a chance to own; it holds no sentimental value beyond that. If I could find another Super Bee that didn't need as much metal work, but needed parts I'd be all up for it. But they're exceptionally rare in my neck of the woods, and being that I've blown all the money I had on this car; I can't really make a deal for another Super Bee for some time.
