themechanic
Oklahoma is OK
- 10:52 PM
- Nov 11, 2012
- Moore, Oklahoma
1969 Dodge Coronet R/T with standard dash and gauges
Now you see me, Now You Don't
I recently refurbished my non rally instrument cluster. The circuit board appeared to be good . So, I cleaned the contacts, installed a solid state voltage limiter, and LED bulbs. I had the switches rebuilt, including the dimmer. The right side instrument lights come on with the headlight switch and dim with the dimmer switch. However, none of the lights come on the left side. I swapped one working bulb from the right with one not working on the left and the one bulb on the left lights up but no lights work on the right; even the ones that worked before. I replaced all the light sockets with new ones. I also ensured I have a good ground. Short of installing a new circuit board what is the solution?
Thanks FBBO
Thanks FBBO
