68 4 Door Belvedere Restoration
harann1023
10:06 AM
Buffalo, New York
I am into a resto on a 1968 Plymouth Belvedere 4 door "K" code police package. I can't seem to find door seals for 4 door sedans? Anyone out there have any ideas or know of a company making 4 door seals?
The cross section is probably the same as 2 dr so you may end up getting 2 dr seals and cutting them to fit. Or search for the bulk material. I used to see it available in auto body supply stores but that was a long time ago. Good luck and don't forget the cop brakes, cop shocks and so on.
Thanks. I appreciate the info. Problem is everything is two door and a two door doesn't have frame around window like 4 doors. Two door seals are easy, you just pop in the plastic clips around the lower half of door. With four doors you have to pop in the plastic clips around lower half of door and top part of seal gets glued around top half (frame) of door. The body shop checked around today and think they found supplier for four door seals. They are supposed to hear back from them tomorrow. Keeping fingers crossed. Thanks again.
Can you get the door seals for a dodge P/U to fit since they require all around the door frame also? Just an idea in case you can't find any 4 door seals.
That is a good idea too. I actually found a complany producing four door seals. steelerubber.com
Car is in final primer. Thanks for the help guys!
