BigFlo
65 Belvedere. I removed my upper cowl to repair some rust on the lower cowl. All along the seam between the upper and lower cowls (except the windshield seam) there was a black sealant. It had a dry, spongy consistency but you can tell it was applied like a sealant at the factory because it wasn't die-cut, etc. It's not a seam sealer like you have on the floor seams either. Anyone have a clue what it is and what it is for? I assume it was for rust protection of the seam, but would it be for anti-vibration also? Is it neccesary to replace it with something similar when putting the upper cowl back on?
