Only if they were cast after December '67 will the VIN be stamped on it.
...Not sure about the second P, may also be a mistake?.....
I have had the impression that it wasn't until '68 that the vin stamps started...
Hello, Are you saying that your 440 block has no serial numbers on it?bought a 68 440 a couple years ago, in the process of building it now , when I got it I noticed there were no vin stamping near pan rail or by bellhousing, today I found this number and it looks like maybe a part number on the underside below the starter , does this number make sense to anyone?View attachment 161040
That fellow joined 12 yrs ago, and was last seen 5 yrs ago. LolHello, Are you saying that your 440 block has no serial numbers on it?
