Jappe
Hi Poly guys,
I am planning to upgrade my 64 POLY engine with a 4 bbl intake/cam and I want to know which parts are recommended.
Which parts should I look for?
Would you prefer the factory one which is a rare option or should I use the aftermarket Weiand intake (and which one is the best choice)?
Are there any problems known about the choke and the kickdown parts referring the usage of the aftermarket Weiand intake (Weiand stealth)?
For know I am using the stock 2 bbl intake with a remanufactured Carter cam as shown on the pic.
Thanks in advance
Thanks in advance
