upnover
looking good, get that thing roadready!
si
si
Got my tire combo mounted and put on the car. Starting to look like a throw back into the sixties now. View attachment 189684View attachment 189685
ok then thanks alothttp://www.speedwaymotors.com/Speedway-Pro-Lite-Vented-Brake-Rotor-1175-x-81-Inch,14004.html
http://www.speedwaymotors.com/Stamped-Steel-Brake-Hat-3-Inch-Offset,1995.html
http://www.speedwaymotors.com/Weld-On-1978-88-GM-Flat-Mount-Caliper-Bracket,21280.html
the bracket has to be welded to the rear end housing. You will also need front brake hoses from a 78 & later monte carlo.
