VFilms
Lowering a 66 Belvedere
I'd like to lower the stance of my 66 Belvedere 318 Poly by 1 to 1 1/2 inches all around. I know a CCW turn of the TB adjusting screw will do what I need, but I also know it will throw off the alignment dynamics. So, I have a few questions... to what degree will the ride and handling be effected, can I still achieve a factory alignment and what is the process to lower the rear by the same amount? I've read other posts, unfortunately not specific to my car, and have seen references to after market hangers that don't require "elongating" the bolt holes in the frame brackets. I've received invaluable help from the fine people in this forum. Thank you.
