727 trans pan bolts
jprather
7:33 AM
Tennessee
ok, off the wall question.. where can i get a set of pan bolts for my 727? put it in the lift this weekend to check trany leak,, well, all the blots are wrong!,, way to long.. someone used nuts as spacers for them.. is this something dodge would still carry? i checked a couple of salvage yards, wont sell the bolts!
any advise??
Can't remember if they are 1/4 coarse or 5/16 coarse thread, but you should be able to buy them at your local hardware store, after you determine the correct length. May not have a captured washer on them but you can add your own.
Mega Parts has the set for $15.
Mega parts sounds like a deal. If you need size info, I can pull a couple of bolts off of one of my spare trans and measure.
-Matt
-Matt
That would be too awesome if you could do that!!
Should be 5/16"x18 just like the oil pan. I was going to suggest oil pan bolts before the other fella said trans bolt kit is available.
thanks!!, i went to mega part and found them!! thank you both for the assist!
