moparjohnny
has anyone removed one from a 69 b body it has 5 1/2 inch bolts 2 on both sides and one in the middle right above the heavy spring,i tried a 3/8 extension with 1/2 socket.but the 3/8 exyension is kinda thick and there is a part of assembly that will not let me get extension down on nut to grip and turn nut to remove,there is a long bolt on the left side that goes to other side that i think that big spring connects to,can that be removed so i can get a ratchet in there without using a extension? any ideas? thanks
