barbee6043
- 12:57 PM
- Sep 28, 2008
- S E Texas. Shepherd, texas
hauled home non running 63 slant belvedere. I changed over to mopar ECU, used old ecu plug in that was missing the 2 wires that go to dist. so I cut 2 off dist and used those for my to dist wires. new batt. reads 12.5 V, key on (ign1)... I have like 5 and 12. 5 at ballast. same 5 at coil +. at ig1 ( run) I get about 5 or so. I jumped the coil + from the batt, and tests 12.5 at batt+... if I crank ( ig2 start) I get 10.5 .
with key on , no jumper to coil, the coil + reads hot but the neg shows no current.
can I have the wires from ecu to dist reversed?? or is another problem. thanks for any input.
