Drum wont come off!!
Don't bogart that joint, my friend........lol
yo,Mario, Sonny checking in here....thought I might have to make a trip down there....bring a few of the boys and take that Drum off, kid! Happy to hear you solved the problem.....(I would make the same mistakes)...so,
fuggedaboudit !
lol no ****, right
Don't sweat it Mar that's how we learn, I'm sure most have done stuff like that at one point, except me of course........ Ok that last part was a lie, I'm sure I've done worse.
btw this is where a shop manual would have come in handy.
Thanks, +6. Funny thing is, I looked in my shop manual and didnt find it!! I must have been seeing double lol! IIRC, it was section 5 page 2.
edit: just looked at the FSM again and it was on page section 5, page 10. dumb ***...
Thanks Mario, the "Funny Forum" was getting a little slow!
But on a serious note, heating and pulling on the drum might have warped the center. It doesn't take much. Check it to make sure it runs true! Ask me how I know...
I checked er out last night. It's all good. spins real nice and straight. Thanks Kid!
Wait until you get ahold of one with left-hand thread studs on the left side!
lol had that happen with the GTX when I first got it. changed them all over to right hand post-haste!
Thanks for the good laugh MarPar . . . if we can't pick fun at ourselves . . . what fun is it ? ? ?
Been there . . .done that . . . ( sigh ) . . . .
Mar if you need to have those drums cut CJC in Lombard still cuts drums.
sweet! thanks Al! I was just about to look around for someone who still does it.
lol amen to that Khan! im just glad I didnt do any damage to the hub!
I wont tell you what I did to the left side wheel before I realized the studes were reverse threads. LOL
The rear drums come off much easier. Just remove the wheel, then the drum retaining clips, and the drum will come right off (maybe, after you back off on the adjuster and a few whacks with the dead blow).
Well not always! I had to take my rear drums off to replace the wheel studs with 3" studs for the track. Loosened the adjusters all the way, bang on the drum from behind with an aluminum drift & 3# hammer. No go. Heated up drums with the oxy/accet for quite awhile & beat with 3#er before coming loose. Turns out the studs that previous owner used with the Moser axles were press fit on stud holes in the drum. Made sure to "hone" the stud holes for the new 3" studs!
Quit using a deadbolt hammer and use a use 3lb mini sledge! The dead blow is like Hitting it with a powderpuff
