Braden
Hi everyone and thanks for having this forum. Anyway, I bought a 1971 charger a couple weeks ago. It's a 318 and needs a lot of love. I'm trying to get it started...I'm using a remote starter switch as the existing wire is going to need replacement and is extremely shotty. That being said here's where I'm at.
Battery negative is grounded. Battery positive goes to starter relay. Then to starter. Then a wire goes to the coil. Which is getting 12 volts on both posts. The plug wire from the coil to the distributor will not spark when I hold it to ground and turn the engine over.
I've replaced the coil, distributor cap/button, spark plug wires and spark plugs. I'm at a loss. I'm sure I've forgotten to mention a few things and obviousally this isn't propper wiring but I'm trying to see it run before I move forward with anything else.
