This is a jegs cam kit, the 528 solid lift cam kit has all the matching valve tran,comp valve springs,comp locks,comp keepers, has new solid lifters as well.235.00 plus shipping.thank you
i called jegs and to check that same thing and was told the number stamped is an old part number,still the same camshaft per jegs. it is listed as p4120659 on jegs site.
