70GETEX
Does the upper trunk trim on a 70 GTX attach with clips or does it attach with double sided tape? I have all of the trim but no clips to attach it.
Thanks
Thanks
Hey Mike, if this is for my 70 GTX you're working on ;) .... why is it that some of the 70 GTXs that I see out there do not have that trim? Personally, I like the rear end without that trim and with the rear lights bezels(?) blacked out ... and the spot where the trim is supposed to be is just the same color as the car.
Are the ones you are seeing REAL GTX's...or clones?
Yep. This is for your GTX! I have the trim but need the clips to install it. The GTX's and Sport Satellites had the trim on the back. Roadrunners and the basic cars were just body color. The GTX had the black paint around the tail lights which makes it look just plain mean and Evil!
This is a good point kiwigtx, I'm assuming they were actual GTXs and not clones...
This is "the one that got away" for me, which ended with me getting the '67 instead of the '70.
http://www.forbbodiesonly.com/moparforum/showthread.php?93238-1970-Plymouth-GTX
That one does not have the black trim around the actual lights that I'm thinking... I'll have to post a pic of it, if I can find one.
Here is one:
Have to agree with Kiwi on the black car, it looks more like a Roadrunner or a Satellite. Need to look at the VIN to see if it is a RS23 for GTX and should be a RS23U or RS23V or RS23R. U code is the 440 4 barrel, V code is the 440-six barrel and RS23R is the almighty HEMI car. Roadrunners would be a RM23 and have a N for the engine code if it was a 383 car and a V for a six barrel car on a 70. The next step it to check to see if the partial vin is on the radiator support, rear trunk gutter and some other places and matches the vin & fender tag VIN #. That should tell you if the car was born a GTX or if someone is representing a car to be a GTX that was born something else.
