midnightrider1818
hey guys. I have something weird going on with the seat belt light and buzzer. I got it to work but this is the only way I can get it to work. ok here goes. first off the light and buzzer will only work with the KEY OFF. I took a 12 v jumper wire and touched it to the top terminal of the relay and light and buzzer comes on. If you do this and turn the ignition on the light and buzzer will not come on. almost like it is losing ground with the ignition on. the seat belt systems are working just as it should. light and buzzer on pull driver side seat belt out and it goes off. clip drivers side and go sit on passenger side light and buzzer come on and pull seat belt out it goes off. So I know all that is working like it should. Ok with the key on I have 12v at the relay and a ground at the relay. I also have 12 v going to top terminal on relay. but light and buzzer will not come on. again if I turn the ignition off of course I lose my 12 v to the relay but if I take a jumper wire and put on top terminal light and buzzer WILL COME ON. If I turn the switch ON buzzer and light will go off. I have constant 12v battery voltage going to the top terminal on relay so yes it is hot whether key is on or of
this has really got me stumped. Again I think I am somehow losing a ground to the light and buzzer when key is on. does anybody have any information on this lol. It has got me stumped. thanks a lot guys really really appreciate everything. I would never be where I am now without you guys.
