Its been a awhile. I found out that if you weld 1/4 plate to the back if the engine brackets and redrill the holes will work on this swap. Also moving the trans crossmember back one inch, and shorten the drive shaft two inches everything works
they are all over ebay and my buddy at RJ's Speed shop makes them too call , talk to cory , tell him i sent you . He will hook you up http://www.rjays.com/
