Hanover Mopar
I have an A&A reverse manual valve body pushbutton 727 in my 63 Dodge 330 (ex-drag car).
I already found out the hard way that you shouldn’t down-shift this unit unless going very slow.
First to second shifts are fine at any speed and second to third shifts work if you keep the RPM’s up when shifting.
My question is; at lower speeds (under 20) can this transmission be put into neutral to clear out the carb when it starts to load up in traffic. I don’t have courage to try it.
Thanks in advance
Jack
Thanks in advance
Jack
