pjm8047
My valve covers are driving me crazy.I just installed some used nos valve covers from a 1970 440 engine 2 weeks which were in great shape. i replaced them because the old ones got over tightened and broke through the bolt holes.So when I installed the new ones I put rtv on both sides of the valve cover gasket and I was still leaking oil from the bolt holes of the covers on to the exhaust manifolds causing it to smoke.I used the torque spec for the bolts from the 71 plymouth service manual which was 40 inch pounds.So I decided to remove the bolt and put rtv on the bolts.When I removed the bolts i noticed that the valve cover bolt hole had broke through again!!Cheap NOS covers?My question is what should I do now buy chrome steel covers and use tabs on the bolt hole? if so I cant find any that have the breather and pcv valve buffles torward the back of the motor.Im lost
