69 RR console top
Garys1969RR
7:34 PM
Colorado
On a 1969 Roadrunner, I am replacing the console top. How do you get the console top off of the shifter? The shifter button is too big for the hole in the console top. Do you have to turn the top sideways, then take something off down below? Not sure how this is done. Any help appreciated. Thanks
assuming this is a automatic car, there is a small set screw behind the shifter ball. loosen this and the knob and button will screw off. the button is what is threaded. but both will turn together. then lift the console top off. if all the screws are removed!
