With the transmission mounts behind me ( kinda ) the Belvedere project has taken on a life of it's own . . . with plenty of thing for me to work on . . . and with the 4 day weekend ( ok, holiday ) I've been trying to keep working in the shop and making progress . . .
The original bolt in cross brace ( under the trans ) can not be used - I'm working on making a new one - but with the new transmission mounts, this under the transmission brace is really for additional side to side reinforcement, and for a catastrophic failure ( although I doubt it'll catch much if the trans fails that much ) . . . one of the through holes for the bolts had to get cut away so the trans would fit in the tunnel - so I drilled a new set of holes, and had to add bracing between the frame to prevent it from collapsing . . . here you can see where I've folded the floor away to weld in the bracing, and am tacking it back in place . . . ( think I may up this to 1/8" steel plating )
WOW - did the floors get really solid with these welded in place and not just spot welded ! !
Got the over the top transmission brace re-designed and fabricated - it's now fully welded in place . . .
Here's a pic of one of my "better welds" . . . this was pretty high heat to really burn these bosses into place . . .
And the view from under the tunnel - with the tunnel in place . . . the drive shaft loop may need to be moved a little up and back
( oh boy ! ! - more things to do ! ! )
Next, get the trans back in place ( again ) and make sire that everything likes up and works ( that I didn't mess up something welding in the bosses ), and if all is well, then the engine and transmission come back out of the car, and the tunnel hump gets welded into place . . .
Then . . . uh, onto Bodywork ? ? ? ! ! ! ( uh boy ) . . .
