dodge1972
Over the years Ive read articles on how to modify a 5.9 to run as an old school setup. For example a 2000 ram truck 5.9 for use in a 74 b body.
1. Replace intake manifold designed for the later engine to support carb set up.
2. Replace distributor to 360 type
3. Install ignition module and related wiring.
4. Exhaust would be basic dual setup
After the above I' not sure about other revision. Any ideas or suggestions
