Northeast300
I would like to change out from points to an electronic set up, does anyone has any suggestions? I have seen some excel stuff that claim to be easy to do but you know the old says, if it seems easy......
Where are you finding good point sets? I have not found any in years.I'm old school ....I'm stilling running points & when adjusted properly There is No problem...
Here's a nice article on points Ignition Performance Test - Ignition Shoot-Out: Points Vs Hei....Very interesting reading
http://www.hotrod.com/how-to/engine/ccrp-9812-ignition-performance-test/
MSD Ready to Run. No need for the additional ignition box. Self contained unit.
I converted everything to factory electronic setup long ago.I was lucky enough to pick up about 20 sets year ago. If you need a set or two I have single & dual points NOS...
